Programming Question
It's supposed to do that - it's called a RPM limiter. You can get programs to raise it, but unless you have modified your engine, you would be asking for a pile of fragmented aluminum and a nice puddle of oil on the ground if you did!
LS1Tech Sponsor
As said above..
A stock valve spring setup can only take 6200-6400rpm before valves float and hit the pistons causing damage.
For programming we need to know what you want to do.Read some of the posts here and you'll see what there is and how much you can do with them.
