P0137,p0151,p0332. Any suggestions?
P0137=o2 sensor low voltage bank 1 sensor 2
p0151=o2 sensor low voltage bank 2 sensor 1
p0332= knock sensor 2 low input bank 2
the car is a 98 trans am a4 that was swapped to an m6 a few years ago. The motor was built during the trans swap. The car has been tuned by a local tuner. The o2 sensors are brand new and the knock sensor has been tested good. If you clear the codes they come right back. Any ideas on what to check? Let me know if you need more info. Thanks
I've got that same P0332 on the Firehawk coming up..i am in need of info.
From what I've found it's a bad Knock Sensor on the rear bank
I have detailed the engine bay a little bit so I'm a bit worried I set off an error code and that the knock sensor took a crap on me
