Help LC9 runs for 2 sec. then shuts off
I just got my LC9 conversion in my Jeep and it runs for 2 sec. then shuts off. My programmer turned off VATS , cylinder de-activation, Body control module, fuel control module etc.
My fuel pump is controlled with a switch on the dash and fuel pressure stays at 59psi. It cranks and fires for a couple seconds and shuts down. My programmer has no idea and I suspect something is shutting off the spark but what could it be? My OBDII scanner beeps and displays "READ" when plugged in but does not continue to read the codes and the check engine light does come on.
The PCM and wiring came with the 2007 LC9 and I wired it into my 78 Jeep using the complete 2007 fuse block. Any help or suggestions would be greatly appreciated.
