Knock sensors
Old 05-10-2010, 08:20 AM
01formulals1's Avatar
Default Knock sensors
Help! I changed both my knock sensors two wks ago and i ran my codes again and they came back up after i had erased them anyone know what could be wrong, also i have some o2 sensors that need to be changed is it possible that my o2s are setting off my knock sensors????
Old 05-10-2010, 08:22 AM
johnrobbins's Avatar
the o2 won't be causing the code. Did you use a scanner to erase the codes. or disconnect the battery and reset it that way?
Old 05-10-2010, 08:50 AM
I used a scanner at first then i disconnected the battery and i took like two days for the ses light to come on again but idk if its the o2s that caused the light or the knock sensors again
