LT1 with classic fast questions
Old 05-16-2010, 12:23 AM
lordrazo's Avatar
Default LT1 with classic fast questions
i have the classic fast for opti (lt1) and the standard wireing harness question i have is will the iac sensor be hooked up? and how to wire in the opti and does anyone have wiring diagram for the lt1 and anyone has some pics thanks guys!
Old 05-16-2010, 09:04 AM
9-Second Club
Ed Wright's Avatar
I'm not sure the FAST "classic" will work with the Optispark. I do tune one NHRA stocker still using that system, (we are changing it to an XFI), but he uses a crank trigger. If you change from an MSD distributor to a crank sensor you have to send the ECU in to FAST for a firmware update. You need to contact FAST about all this. As for the IAC, you can use it or not. Many races do not, they simply zero that table.
Old 05-16-2010, 11:58 AM
lordrazo's Avatar
it does work with the opti i sent it in to fast and for $50 they converted it from hei to opti and bench tested
Old 05-17-2010, 03:33 PM
9-Second Club
Ed Wright's Avatar
Check your email.
Ed
Quick Reply: LT1 with classic fast questions
