Tough LS1 PCM question, let's see who can get it?
OK, here we go with the question of the week with LS1 PCM's.
Does burst knock show up as knock retard using autotap or your favorite scanner? Burst knock is the timing the PCM will pull when it senses a large change in airflow very quickly to prevent knock. This doesn't mean it hears knock and pulls timing, it pulls timing to prevent it from occuring.
Maybe. I didn't know there was such a thing, but I think my car does it. Now that I have resolved my lean condition, the only KR I see is when I first go WOT, and a blip when it shifts.
"A table that defines the Gms/Cyl change in Airflow to initiate
Burst knock, More commonly called Tip-in" taken from the LS1Edit update list.
I was not aware that that was a feature of F-body PCM's and am not up to speed on other applications. Will refer this to the expert on this topic. Stay tuned...
Regarding Burst Knock. If I start logging with EFI with only the key on, I will sometimes see a spark spike when I start the car. That may be one example?
BTW, see here for data on Torque Management - the drivetrain protection system:
http://www.efilive.com/forum/viewtopic.php?t=314
Blip on ignition is prob a system voltage spike..... alternator field enable, pcm initialise, AIR pump drawing gobs of current.....
Is that the case even if it shows up as knock retard?
Burst knock will "not" show up as 'real' knock retard in a scanner because knock never actually occurred, just look at your tables to know how much timing it will pull out and what parameters will allow burst knock to occur.
Oh, what do I win.
Oh, what do I win.
Originally Posted by Nic00Z28M6
Nothing yet. Tell me why as a test I deleted both knock sensors, yet when I would wack the gas in gear I would see knock retard then it would dwindle down quickly. What could possibly cause knock retard if both knock sensors are turned off? Do you have any proof or documentation for your "theory"?
Deleted as in deleted the code's for the sensors in the engine diagnostics. I am speculating that deleting the codes for the sensors will disable them entirely, same as every other sensor/code in the PCM. Not to mention I could sit there and rap on the head with a hammer prior to the code deletions and see knock retard activity but as soon as I deleted the codes I could register no knock with the hammer. Again, do you have any proof or documentation for your "theory"?
These PCM's have a 'default' knock retard value if there is a problem with the ESC system (yes I know you disabled the knock codes from setting), but think of it like this, the EGR can be totally enabled/disabled right (LS1Edit - EGR Enable/Disable), and you can also turn off the EGR codes from settting.
So turn off EGR processing AND turn off EGR DTC's, get the picture...
You are turning off the ESC DTC's (read the line above again).
Another way to test whether you are seeing burst knock or real knock is to go into the PCM and change one of the sets of tables to zero. First, set all the burst KR tables to 0 and see if your KR still happens. Then, put burst KR back to stock and set all of the normal KR tables to zero....
This should tell you where your KR comes from.
Regarding timing spikes... remember that there is also an airflow spike at tip-in. If you look on the stock timing tables at low RPM and high airflow, the timing is quite a bit lower than in the power band. The timing dip you see at tip-in may just be the correct value from an unexpected place on the timing table (for example: 1.25 gms/cyl at 2000 RPM).
cheers
cheers
What's up with the smart **** attitude you have displayed the entire thread??.
These PCM's have a 'default' knock retard value if there is a problem with the ESC system (yes I know you disabled the knock codes from setting), but think of it like this, the EGR can be totally enabled/disabled right (LS1Edit - EGR Enable/Disable), and you can also turn off the EGR codes from settting. So turn off EGR processing AND turn off EGR DTC's, get the picture...
Staying tuned for emarkay's findings.......................
joel
I would rather not try it that way and that is why I am asking this question to see if anybody knows this for a fact and if they have proof like something from a GM PCM manual, documentation, etc.
Delphi Corporation
World and North American Headquarters
5725 Delphi Drive
Troy, Michigan 48098-2815
USA
Tel: [1] 248.813.2000
Right, a tuning manual for the LS1 PCM, try here
