PRC 5.3 Ls1 set up's timing?
Hey guys what timing are you you running on your slightly higher compression ls1 set ups arround 11:1 or so?
Ive got 59cc milled Prc 5.3 heads and 228/230 .588/.592 112+2 ls6 intake combo right now and am set at around 25 or 26 currently. I feel like I could run some more but understand more timing does always mean more power. Just seeing what you are are running and the results. Hopefully TSP will step in.
1 Post
The only right way to find out is to put it on a dyno and see what it wants... From my experience, yours is probably about where it should be. But noone can come in a post and tell you whether it needs more or less - only the dyno can tell you what the combination needs...
