My car has 3 Codes.... What do I need to check ?
My 2002 SS is throwing 3 codes. I looked them up and this is what I found.
P0200: Injector Circuit Voltage.
P0442: Evaporative Emission Control System Leak
P1416: AIR System Bank 2
Now, where should I start looking or checking ?
For the P0200 I would start with the underhood fuses, then check your injectors are all tightly plugged in. After that ohm all the injectors and finally visually inspect the wiring.
For the P0442 I would make sure your gas cap is tightened correctly.
For the last one it sounds like the check valve is stuck.
