Shift point settings after 3.42 gear swap a4
I posted this in the gears section but figured it may be better suited in this section... My 3.42's are in and I'm taking it to the tuner this week to have him reset the speedo and shift points a little biut as I hit the limiter on the 2-3 shift now. My tuner probably will know this but I was wondering what most people here set the shift point mph at with 3.42's in an a4. My buddy just did 3.73s in his car and while it came to be calculated the car should shift at 68 at 6000rpms it was hitting the limiter at 6200 and the points had to be backed down to 64. Just looking for someone whos done it to possible save the tuner and I a small snag. Thanks Dan
Sorry kinda forgot abt this thread anyway gears were installed and tune everything seems to be good the wot shift points didnt have to be adjusted as they werent hitting the limiter at all. Just wondering obviously traction is now and issue and i cant seem to launch at all from a roll or dig without spinning. When this happens the car is only shifting at 5k-5500 rpms wot it did shift at 6k once when it got a good hook. Jw if this is typical of the autos when the tires start spinning my 2.73s would do it occasionaly when they would spin from a roll..
Does anyone know what the stock shift point rpms are for our cars? I ended up getting a hold of a handheld scanner and observed the shifts the car was shifting anywhere from 5600 on 3 tries and 5700 on only 1 try. Mph for the 5700 shifty was 42 which is right on the money for that rpm. I was thinking of having it raised to 5900 rpm which is also 43mph on mon is that pushing the stock valvetrain or is it ok should I go high possibly to 6k?
