I need some numbers badly.
I'm running a dyno program and I need to find:
Piston Down from TDC,
Volume above piston,
Intake valve diameter,
exhaust valve diameter.
Induction Flow
I'm programing an engine I plan to build so I don't have most the parts on hand so measuring them is not an option.
I'm building is a ls1 block honed to 3.903, patriot stage II 59cc heads (.650 dual springs), 102mm FAST intake set-up, +2cc forged pistons, stock crank. What would those numbers be?
Induction Flow
