Cam Position Sensor
Cam Position Sensor
Nothing but a nightmare. I keep setting P0342 and now P0341. High and low errors. Can I just delete these codes? I'm tired of not having a tach. The tach will work for a second or two when I clear the codes, but then just dies again. I have replaced the sensor, and traced the wiring back to verify it's good.
Both high and low signal from cam bolts? I was only getting low signal before, twisted the wires together and it held for a single pass. I have since scotchlocked them and now have the high and low signal issue. High would denote a bad sensor, and low would be a loss of continuity, right?
