First logged test drive, LOST about config setup HELP !! LOL !!!
Hi Guys,
I have not had any luck getting a good cfg setup to properly analyze my tune. I can't get AFR Error to populate although the recorded AFR is accurate. I think I am pulling info from different examples of threads I have read and my mind is spinning in circles.
Probably running through the forest and not seeing the trees
I must have errors in the PID's that I created to record E85 AFR.
I would LOVE to have the config set up for lambda since the E85 blends in my area vary from E75 to E85 from time to time.
If someone has a cfg for a LM1 wideband setup that would be a HUGE help.
Keep in mind that the LM1 was not set up right for the first test drive log.
I lost contact with the guy that helped me with the base tune, so this has become a quick learning curve.
Thanks in advance,
Jim
ps paypal ready for a case of GOOD
My log, tune, and cfg files are attached to my thread over at HPT.
http://www.hptuners.com/forum/showthread.php?t=30637
Thanks in advance,
Jim
make sure you are looging commad AFR, im at work so i cant look at your log, thats prolly the reason that table will not populate. hopefully someone that knows more than me will chime in and offer more help
