How much timing does traction control pull?
Just curious. My car blows right through traction control even though Ed told me that he never touches the settings due to liability which makes sense. The car is insanely quicker qith it turned off so I know it's working but it will still blow off the tires in the first 3 gears with it on.
I dont touch the tractions control tables either because if you are not in competative mode, you want them there to save you. I remember you installing a new PCM, but cant remember if it was new or from a 2001 + car. without looking at the tables, Id guess Ed left them stock.
Installing 1.30 gears ratio maybe help you with traction
