new be ve tuning question
Old 08-14-2010, 10:19 PM
dwnshft82's Avatar
Default new be ve tuning question
i am trying to tune my ve table using the ls1 tuning free help the afr commanded hi res is saying 14.6 and i am getting it pretty close i fell like i should be tuning it to 12.8 across the board if so how do i change the commanded afr to 12.8 or am i supposed to tune to 14.6 at part throttle and only 12.8 at wot
also i just put in a t56 magnum and the vss gear is different 12 teeth instead off 17 i changed that figure but believe i need to change the vss pulse per mile also can hp tuners do it or do i need some equation where i put in tire size and gear ratio to get it
thanks to all
