Need Help motor idles but wont revup( Got data log posted )
Ok so i have been searching for 2 nites and nothing....heres the deal 5.3 ls1 intake modded my stock harness ls1 hotcam 30# ford redtops lt headers 2000 chevy pcm t56 trans tuning done by lt1pcmtuning. I got 58psi at the rail car starts kinda hard but idles as soon as u touch the throttle it tries to die. It stumbles constently if u hold it open it pops threw the intake if u tap it it will eventually revup but once then it gets up to 1500rpm and the injectors just cut off and once its back down to the idle they come back on (noid light) oh and its running really rich. It will idle all day fine. Goin crazy need some major help also its in a 67 camaro.
data log got the rear o2 sensors deleted
______________start up _______at 1 minute in___30sec later_____2sec later
load_______________5.5_______2.7______________5.5_ _________14.5
coolant____________104_______120______________126_ ________125.6
st fuel trim b1______ 00 ________00_______________00__________ 00
lt fuel trim b1 _______00________00_______________00 __________00
map________________86________87_______________71__ _______ 93
rpm________________697_______515______________1030 _________810
speed______________00_________00_______________00_ ________00
timing______________32________27.5______________29 _________14.5
air temp____________84.2_______84.2_____________82.4__ ______82.4
maf________________13.4________6_______________30_ ________24.7
tps__________________0________66.7_____________0.0 _________45.9
o2 b1 s1____________.445_______.445____________.445_____ ___.445
o2 b1 s2____________.445_______.445____________.445_____ __.450
o2 b2 s1____________.170_______.150___________.170______ __0.00
o2 b2 s2____________.445_______.445___________.445______ __0.00
o2 b1 s2 stf __________0_________0______________0________-100.0
o2 b2 s1 stf__________0_________0______________0_________-100.0
o2 b2 s2 stf___________0_________0______________0________-100.0
sorry i cant figure out how to post the data the car idles fine but when u try to give it any type of throttle stumbles trys to die of u tap on the throttle fast it will rev up slowly then it stalls till idle again goin crazy
