How To Hook Up Hawker Battery?????
Old 01-27-2004, 04:14 PM
98sspullin'em's Avatar
Arrow How To Hook Up Hawker Battery?????
How do you get the stock cable that screws into the regular battery to screw into the Hawker Battery....and how do I get the screw out of the wire?
Also should I get a bracket to hold in the battery for daily driving use, or can I just let it sit in there?
If so, where can I get one?
Thanks,
Dwayne
Old 01-28-2004, 06:58 PM
MIGHTYMOUSE's Avatar
the posts you can find something that will work from pep boys.. but i just used a longer 10mm bolt (lots of em on the car) and a washer through the stock terminal (after you pry out the factory screw)
you can see it barely in the corner of the hood photo.. and this is a side view of the bracket i made out of sheet metal.. it uses the stock bolt and kinda pins the battery under the other end.. i have some small fuel tubing underneath conform to the battery... it worked for me
if you go to the dragstrip you will most definitely have to hold it down somehow.
