SD tuning option
Old 09-19-2010, 11:00 AM
BOTTLE ROCKET's Avatar
Default SD tuning option
Due to the issue with my Maf maxing out (previous post) I have ordered my 2 bar MAP and will start working on my SD tune.
I've read several bits and pieces of the process, but nothing that outlines a start to finish process.
Does anyone know where I can get a through write up?
Old 09-19-2010, 11:11 AM
MUSTANGBRKR02's Avatar
There is none that I am aware of.
Old 09-19-2010, 01:16 PM
WS6HUMMER's Avatar
http://www.hptuners.com/help/demos/2%20bar%20sd.swf
Old 09-19-2010, 03:13 PM
CalEditor's Avatar
Switch up to a 99 or newer PCM. Then the MAF will work also
Old 09-19-2010, 03:37 PM
The 99 only goes to 12000hz, and I am WELL over 13000 at only 5400rpm
Old 09-19-2010, 04:00 PM
WS6HUMMER's Avatar
I scanned a proocharged truck with the same problem recently. The owner just wont go 2bar SD, I guess when it goes lean and its torn up he might consider it,lol.
Old 09-19-2010, 04:04 PM
Always forget about that,lol
Old 09-19-2010, 04:06 PM
WS6HUMMER's Avatar
Yeah, there are a lot of new ones in there that they've added recently, you should check it out.
Old 09-19-2010, 05:28 PM
CalEditor's Avatar
I see. I missed that the other day.
I did would think a 0411 PCM will work better anyway. I would use a 2001 Operating System. 12202088 or 12221588. You still need to go to SD or purchase an Abaco tunable MAF. The 0411 is a better PCM for boost and they are hard to Brick. The 98 operating systems table are not as favorable and the PCM's brick often.
