Autometer wideband a/f ratio install.
Old 11-07-2010, 10:16 AM
AUTOBUC's Avatar
Default Autometer wideband a/f ratio install.
Installing autometer wide band a/f ratio meter. Anyone know wiring procedure
for 2000 WS-6. specifically the brown wire option that requires a monentary
closed wide open throttle switch. and the blue/black, blue wires which are wired to the data logger output (engine managment, data aquisition unit)?
I assume the switch has to be installed off the throttle? were do I
locate this switch Thank You "Last of the Breed"
ANY ONE KNOW BENEFIT OF MOUNTING A WOT SWITCH OFF THROTTLE AS
OPPOSED TO GROUNDING CONSTANT. HAS ANYONE PERFORMED THIS??
Old 11-09-2010, 08:10 AM
AUTOBUC's Avatar
Why no response from anyone regarding this question??? I would think it is
a popular issue considering it to be related to pcm tunes?????
Quick Reply: Autometer wideband a/f ratio install.
