Need some help(i posted this on hp tuners too)
Ok so I have been running the car up to about 3800 and at one point heard a loud bang 2 days ago at about 2800. It didnt throw any codes, and it also didnt bring anything up on KR? I have been driving it for the last 2 days still trying to get my VE correct and can not get it to reproduce the same noise. If i had a broken valve spring would that show anything noticeable on the scanner? Would it smoke at all? If it was a rocker or lifter would that be noticeable on the scanner? Im hearing a constant ticking at idle but nothing out of the ordinary while driving through the RPM's. From what i have read on LS1 tech the ticking at idle could just be the injectors ticking? I'm also wondering if it was the tranny mount breaking or the exaust poping off the bracket on the tranny? Its off of the bracket but can't remember if it was ever on it. Any ideas
A broken rocker arm or spring should make the car miss consistanlty, not just once. I would think if you were working on the VE then you might of heard un burnt fuel igniting in the exhaust pipe, a rich condition, or maybe a lean backfire. As to the scanner, yes you might see a lean bank on the NB's, due to the cylinder with the problem not burning all the O2. IF it popped once and quit then you probably caused it from fueling.
