Swap efi live tune to hp tuners.
Old 12-16-2010, 08:39 PM
JankesGTO's Avatar
Default Swap efi live tune to hp tuners.
As the title states I have a ECM tuned with efi live but all the local tuners I know of use hp tuners. I have the efi live files for a couple of different setups. Was wondering if anyone had both software and I could pay them to convert the tunes over to a hp tuners tune?
Old 12-16-2010, 08:51 PM
Frost's Avatar
just the read the file out of your PCM with HPTuner's.
Old 12-16-2010, 09:13 PM
SRTKLLR's Avatar
Like he said. Have your tuner read it with his HPT and he can make all the changes he wants then reflash it. You can later read it with your EFIL and make other changes if you wanted as long as neither of you lock the tune or do some sort of COS.
I have been reading and writing my brothers 2010 Camaro with both EFIL and HPT with no problems.
Frost, I will be using the E-85 tables with a switch that EFIL offers. Is that considered a COS? Because I want to be able to have it read by the tuner and he uses HPT.
Old 12-17-2010, 10:23 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
if the your e85 setup runs on a EFIlive OS then the Hp tuners wont read it... if its a factory OS then there will not be a problem
Old 12-18-2010, 09:25 AM
JankesGTO's Avatar
There must be some sort of efilive os because hpt will not read it. I forget the exact error message we got but he told me it was the same one he gets when he has the scanner tool running and tries to read it. I really hope we don't have to start from scratch.
Old 12-18-2010, 10:32 AM
Frost's Avatar
The scanner will scan a locked / custom OS'd PCM... make sure the OBD port's fuse is good. If it's an f-body, it;s the same fuse for the cig lighter.
Old 12-18-2010, 11:44 AM
JankesGTO's Avatar
Yea we were able to scan and see rpm and what not but could see fuel trims or anything. It was weird it's a truck
