P0327 Code ?
okay after some reading I found out that it pulls timing,Recently installed a ls6 intake on my brothers car and this code pop up I must have did something to the knock sensor wiring harness.Can someone confirm this? thanks
https://ls1tech.com/forums/pcm-diagn...causes-kr.html
P0327 is the front sensor... but you can set only 1 code w/a pinched wire... I somehow did it heh
I pinched the KS harness between the lifter valley cover (LS6 PCV swap) and block... only pinched a small amount though... but was only causing P0327
Problem is when you set this code, the PCM sets 4* of constant knock, and drops to the low octane tables... so you get like 15* advance at WOT heh
