C5 Idle Relearn?
C5 Idle Relearn?
I just installed a Texas Speed 228R cam in my 02 Z06. Everything is great with the motor and I have a date with my tuner Tuesday. My problem is that it will not idle at all. I would like to drive the car around just to let it go thru some warm up and cool down cycles before it hits the dyno Tuesday. I have read about the C5 Idle Relearn by pulling a couple of fuse's. Will that procedure help my idle problem? I don't want to screw anything up before it goes to the tuner but if the relearn procedure would work I would try it just to be able to drive it around some before Tuesday.
