logging with hpt standard
Old 02-23-2011, 10:27 AM
Dave_the_SS's Avatar
Default logging with hpt standard
so im debating to get the pro or standard package from hptuners. i know that you can hook up a wideband to the standard also.i had spoke with a vendor about this. was mentioned that the afr logging would be a bit hard to tune with due to the response time in signals.
my question is if you have a lc1 and log off of that would you have the same problems with the signal response time? vs hooking the lc1 to hptuner and having to wait for the signal to jump from one signal to another then finally to the computer.
Old 02-23-2011, 05:56 PM
flame's Avatar
It really depends what you want to do with it. If you want to be able to stick a wideband in any car and tune/log then go with the pro. If you want the real time tuning to work you need pro. I wish I had gotten the pro and its much cheaper to do it right off the hop then to upgrade later.
Old 02-23-2011, 07:27 PM
robbyredneck's Avatar
pro. the importance of the scanner is totally under rated and having a fast response is imparative. i was on the fence also and man am i glad i got the pro. you need the wideband in the scanner so you can set up % error properly. this makes tuning way more efficient.
