tune after fuel pump install?
If you just replaced the stock fuel pump, then you shouldn't have to. If you installed an aftermarket pump, they typically increase fuel pressure compared to stock. However, it really depends on the fuel pressure which you need to measure at the rail.
If the tune was based on adequate pressure and the pump failed later, you'll be fine.
