max micro tuner
It looks like it works on 99 to 2002..
Here is what I found :
Eastwood is proud to introduce Superchips MAX MicroTuners. If you want a quick and easy way to increase Horse Power and Torque, Superchips MAX MicroTuners are the answer. In just 10 minutes, Superchips allow you to reprogram the ECU to boost HP up to 10% and Torque up to 13% using the vehicle's diagnostic port. Simply plug in, answer a few questions and unplug to complete the process. Increases engine output throughout the entire RPM range for improved low end and full throttle performance.
Superchips MAX MicroTuners also offer built in code scanning capabilities. Superchips MAX MicroTuners will raise or eliminate top speed limiter*, increase rev limiter*, adjust automatic transmission shift points*, calibrate for changes in tire size and gear ratio*, and increase hauling and pulling power. (* not available on all applications)
For most applications, Superchips MAX MicorTuners also offer DualTune or TriTune programming. This feature allows the option of selecting between different levels of performance gains based on fuel types and/or towing needs.
Eastwood offers Superchips MAX MicroTuners to increase the performance of your Cummins, PowerStroke, or Duramax Diesels, as well as Ford, GM, and Dodge gasoline engines.
Part Number Application Year
25126 Ford 7.3L TDI Trucks, Vans & SUVs (PowerStroke Diesel) - TriTune Programming 1994-2003
25127 Ford all V8 & V10 Gas Trucks, Vans, & SUVs - TriTune Programming 1996-2003
25128 Ford 4.6L V8 Mustang, Crown Vic, Town Car, & Continental - DualTune 1996-2003
25129 GM 4.3L V6 Only 2001-2002
25130 GM 6.6L Duramax Diesel - TriTune Programming 2001-2003
25131 GM all V8 Gas Trucks, SUVs, & H2 - TriTune Programming 1996-2003
25132 GM Camaro, Firebird, TransAm LS1, LS6 (5.7L) GM Corvette LS1, LS6 (5.7L)
1999-2002
1999-2003
25133 Dodge Cummins Diesel 24V - TriTune Programming 1998-2002
25134 Dodge Ram, Dakota & Durango V6 & V8 Gas Trucks 3.9L, 5.2L, & 5.9L - TriTune Programming 1998-2003
NOTE: Only Superchips that are tested to verify that the customer has returned the application vehicle to "stock" condition will be credited, if returned..
Frequently Asked Questions
Q Will it void my warranty?
A No, generally speaking, it is illegal for a dealership to void your warranty based solely on the fact that you have installed an aftermarket product. If in doubt, be sure to consult your dealership before you use this product.
Q Will it damage my transmission?
A No. In some cases, transmission operation is improved.
Q How difficult is this to use?
A Most customers with minimal mechanical skills can use Superchips MAX MicroTuners.
Q Can my vehicle be returned to stock?
A Yes, by simply removing the program setting.
Q Will this product increase my gas mileage?
A While this product is designed for more performace, in some cases the vehicle may get better fuel mileage.
1999-2002
1999-2003
