What do you think about these O2 readings?
This is from an AutoTap log, at idle only..... What are you thoughts about the Bank 1 sensor?
I haven't switched the sensors to opposite sides, but I found it odd that it was reading a value, just not varying like normal. Also, this has caused the LTFT for bank 1 to hit max of +25%
had the same thing go on my 98 ws6 yesterday....i have a gm tech 2 and i read the code reset it and it hasnt come on yet again.....if u havent reset it i would take it to ur dealewrship and have them reset the code and go from there...if it continues it most likely means u have a bad o2 sensor....hope that helps
