cant keep running
cant keep running
370 ls, 85 lbs injectors, ls6 intake, ported 862 heads, gt-88 turbo, TH400 94 trans am. New set up and tune
The car turns over and starts but dies with in a few seconds, Ive got fire, but all the plugs are wet with fuel, it stalls out like its dumping to much fuel.
Took it to my tuner, he plugged it into his laptop and said it had a bad Map sensor. I put a new Map sensor in and its doing the same thing.
If I unplug the MAP sensor I can keep it running but it still wont Idle, with map sensor plugged in it wont run and is getting way too much fuel.
Any suggestions would be appreciated.
