6.0+Tourqer V2 cam= Idle searching/stalling
Hey guys, i just upgraded from my wore out 5.3 i swapped in my 98 blazer to a 6.0l and installed a tourqer v2 cam. I had a buddy send me his tune with the same setup but he had bigger injectors and a stall. so i just used his idle tables , timing ,and engine size..no ve or fueling becuase his injector size difference .
So now to my problem. I start it up it will idle for a sec and die or start idle searching/surging and die unless i just give it 2% throttle. at 2% it idles beautiful
Im new to the cam tuning and would appreciate info on causes and correction. Im using hptuner pro and just got this thing going last night.
It sounds like it needs more airflow - did you adjust your base running airflow tables at all? Did you adjust the throttle body at all (i.e. do you have a set screw you can adjust the point where the throttle blade sits at rest)? Do a search on HPT or here for "RAFIG"....
Also - the stock VE will be dumping too much fuel in under 1600 rpms. So, you'll need to adjust the VE to get it to idle smoothly.
I didnt adjust the throttle body because i always heard its a bad way to fix the problem and should adjust the tune.. but yeah thats what i was thinking of doing but didnt want to cause any other issues with the throttle being slightly opened.
im about to check on the base airflow tables , i believe i had copied all those off my buddies tune
If he entered in the correct injector data when he did his tune, the MAF and VE should be correct (or close to it) for you as well. The scaling would have been done in the IFR table. You can try copying over the tables (MAF/VE/RAF) and testing them as a base. But, every car can be different. So, I'd highly advise the use of a WBO2 to ensure you're not dangerously lean/rich on AFR's.
