Can you use OIL PRESSURE 5v for Wide Band o2 in HPTuners?
Old 07-08-2011, 03:33 PM
dville_gt's Avatar
Default Can you use OIL PRESSURE 5v for Wide Band o2 in HPTuners?
Just like the title says, I know people use EGR and AC pressure, I am using a 04 Express Van PCM, no EGR and no A/C pressure (just a simple high/low pressure switch setup).
I am not using the oil pressure sensor so I figure I could use it to get my wideband data.
Any idea?
Old 07-08-2011, 03:59 PM
1964VETTESSLSX's Avatar
Yeah you can use any 5v feed you can find unused in the harness
Old 07-08-2011, 04:01 PM
dville_gt's Avatar
Strange how I haven't seen anyone doing this. I guess because most people actually use the oil pressure sending unit? I have autometer gauges so that is not a problem.
Old 07-08-2011, 08:01 PM
joecar's Avatar
You can input a voltage via EOP only if EOP was enabled (i.e. if you could log the EOP pid).
Old 07-08-2011, 09:52 PM
TransWS6Am's Avatar
are you sure there isn't a pin on the pcm for EGR? I have an 2001 Trans Am (no EGR) but the pin is still there for EGR on the computer, I tapped right into it, to log AFR on HPTuners. If there is no pin for EGR, I would be willing to bet there is a PIN for A/C is on the computer, you just have to tap into it directly at the PCM.
Old 07-10-2011, 02:11 PM
joecar's Avatar
There is a pin for EGR... but you also have to enable EGR and zero out the EGR timing table.
Old 07-11-2011, 10:34 AM
dville_gt's Avatar
What pin is it? It obviously isn't listed on the PCM pinout since the car didn't have it.
Quick Reply: Can you use OIL PRESSURE 5v for Wide Band o2 in HPTuners?
