Check engine light disappeared by itself
Old 07-26-2011, 09:55 PM
rxrom's Avatar
Default Check engine light disappeared by itself
My 2000 trans am has had the check engine light on since I bought it last year. It was code p420 low efficiency catalic converter left bank. I tried clearing it but after 10 miles of driving the light alwas came back on.
Today while driving the light disappeared and so far isn't coming back. Can the computer clear a code by itself?
Old 07-26-2011, 09:57 PM
rxrom's Avatar
I thought the light burnt out but it lits when the key is turned to on
Old 07-26-2011, 10:11 PM
GulfCoastWS6's Avatar
If you have high flow cats or no cats it will trip.... other than that it could be the oxygen sensor or catalytic converter is bad. po420 is the back sensor reading i believe so the car should be running fine.
Old 07-26-2011, 10:26 PM
Snake_Skinner's Avatar
Yep happened when my cat went bad.
Old 07-27-2011, 09:29 AM
madmax4499's Avatar
yes, the light can reset after several drive cycles.
Quick Reply: Check engine light disappeared by itself
