Which Wideband for HPTuners?
I use the LM-1 for tuning. I recently purchased the LC-1, but returned it because the cord was to short for needs. I then purchased the LM-2.
I continue to use the LM-1 for all my tuning and use the LM-2 as back up. I plan to switch them soon and use the LM-2 for all my tuning and the LM-1 as back up.
There are several good one's out there just depends how much you want to spend and what is the application. I need to change my wideband from car to car. If I didnt do that, The LC-1 would work.
Thanks for the replies!
Never used an Innovative product but when I was searching for which wideband to buy a week ago I read so many threads full of people complaining about the LC-1 ..seems like you have to wire it perfectly(mainly the ground) and even then a lot of people could never get it to work right.
Not saying it's bad, just letting you know what I found doing a LOT of research. I found very few complaints about the AEM UEGO and decided to go with that, finished the install today so I can't say much about it ..the install would be a breeze for someone that is half decent at wiring, I am not so it took a while to get it working(completely my fault) but so far so good.
The major concern is that the ground location is the same as where the pcm grounds on the head. Pretty minor. I just butt connectors for all my connections with no issues.
