HELP! 36lb/hr GTP injector hp tuners
Old 08-02-2011, 10:55 PM
mikeyc34's Avatar
Default HELP! 36lb/hr GTP injector hp tuners
i need to adjust the fuel tables in hp tuners and did not know where to get the information to fill in. i know there are 4 tables that are supposed to be modified when upgrading the injectors. i have the 36 lb/hr gtp white injectors. i will be running them at the stock 58 psi. any help would be greatly appreciated. any links to old posts or the fuel tables would also help.
thanks
mike
Old 08-03-2011, 12:33 AM
jdaniels's Avatar
They were used in the factory ASA Corvette as well at the same fuel pressure. Download the Corvette ASA tune from the repository and do a compare, copy all injector related tables to your current tune. You can get the txt files with the table data here as well: http://www.hptuners.com/forum/showthread.php?p=215254
I switched to EFI Live or else I would just send you my tune so you could copy the injector tables.
Old 08-03-2011, 09:48 PM
mikeyc34's Avatar
thanks for the info i got it all set up today and ran really well. i will see soon how it works in real world driving once i get the rear end back in.
Quick Reply: HELP! 36lb/hr GTP injector hp tuners
