EFILive error message w/ pictures
Old 08-05-2011, 10:10 PM
Tan327's Avatar
Default EFILive error message w/ pictures
Was scanning the car fine and decided to add the o2 sensor voltage pids, they didn't pick up so I turned off the car and cycled power on the scanner. Now every time I turn the scanner on it detects the wrong controller(used to show the E38 ecm, now it always shows the Flashscan/Autocal picture ...after I select the right one it seems to connect fine, but then when I go to scan I get the error in the second pic below and it will not scan.
This is EFILive v1 7.5. Thanks!
Attached Thumbnails EFILive error message w/ pictures-efi2.jpg   EFILive error message w/ pictures-efi.jpg
Old 08-05-2011, 11:53 PM
DrkPhx's Avatar
Make sure you've selected a valid pid specific to the ECM you're scanning and validate it by selecting Info>Validate pid.
Old 08-06-2011, 11:16 AM
Tan327's Avatar
Thanks just tried but the Info>Validate pid selection is ghosted out and I can't select it.
The controller seems to be working fine seeing as I just did a reflash, but I'm still having the same issues with the scanner.
Old 08-06-2011, 01:17 PM
Tan327's Avatar
I reinstalled 7.5 and the error is gone now but when I start monitoring it instantly pauses and will not monitor. I hit the pause button and it says recording but the top of my screen just flashes and goes crazy & will not record or monitor..
Old 08-06-2011, 02:39 PM
Tan327's Avatar
Uninstalled 7.5 and installed from the disc that came with the software, version 7.3, and so far everything works as it should.
