OBD1 To OBD2 Plug conversion?
Old 08-27-2011, 01:13 PM
Liftedsilvy's Avatar
Default OBD1 To OBD2 Plug conversion?
Im trying to change my OBD1 Plug to a OBD2 plug so my Tunnercats cable will work. I have tried to rewire the new OBD2 plug and cant seem to get it to work. The car is a 94 so there is no power at the factory OBD1 Plug If found the data wire and pinned it into 9 on the OBD2 plug and 4-5 are grounds but my Tunnercat cable only has prongs on 5-6. Has any one ever done this swap any input would be greatly appreciated,Is it mandatory to have power at the plug?
Old 08-27-2011, 01:27 PM
popethe5th's Avatar
yes you must pin power into the plug, when I did this I bought a 4 foot obd2 extension cable and lopped off the female end and pinned everything directly into the PCM. but your 94 PCM isnt gonna work, youd have to get a 96 i dont think 94PCM is CAN cabable. I gave up and went to EFI 24X set up its the only way to go
Old 08-27-2011, 01:35 PM
Hmm. Ok so my 94 Pcm isn't tunable with the cable? I read somewhere i could just change the plug and tune it with a OBD2 Plug?
Old 08-27-2011, 01:40 PM
2xLS1's Avatar
Be more specific about what tunercat cable you are trying to use.
Old 08-27-2011, 01:48 PM
I bought it used Its a blue ended obd 2 cable my buddy was using to tune his lt1 turbo car It only has a few prongs inside ,9,12,7,6,5,It says obd II Auto X ray on the OBD2 plug
Old 08-27-2011, 03:30 PM
popethe5th's Avatar
I have a cable that converts OBD1 to a USB connection PM me and I will sell it to you seeing as how I have no use for it
Quick Reply: OBD1 To OBD2 Plug conversion?
