Looking for stock numbers
Hey guys - Hoping someone will be able to help me out.
Long story short, my car started to get real crappy mpgs over the past couple weeks. After I put my rear in my mpgs dropped a bit, but lately, I"m getting 160 a tank.
I've check the tires, all running ~32psi, the plugs and wires are new, I recently replaced the fuel filter and I'm pretty good about running fuel injector cleaner through the lines.
So digging around on here people said that the o2 sensors and sims could be going bad but not bad enough to throw a code and same with the MAF.
A buddy at work gave me his DriveRight CarChip to get some numbers from the car (checks everything from fuel pressure/timing/02 etc.).
All this is great, but if I don't have any numbers to compare them to...it was useless. So I'm looking for someone to shed some light on what my MAF should be at, same with 02s, also fuel pressure.
I did some digging but can't find ****. Also since I'm new to this, I'm not realy sure what I should be looking for.
Any info would be a huge help.
Thanks
C
Thanks
C
