2005 LQ9 and FBody wiring/PCM
I apologize if this isn't on the right section....
I've searched a bit and I can find nothing on here.I just wanna confirm what I'm trying to do is ok....
I have an 05 LQ9 and I'll be using a FBody 4L60E behind it...
Can I use an Automatic F-Body PCM and Harness for my LQ9?
Thanks
Thanks
I did a lq4 swap and used my fbody harness I think the only thing u will have a problem with is INJECTORS . Which Texas speed helped me with and I bought a ls2 rail and ls1 style INJECTORS and worked just fine or he said u can get the adapters that will work with those injectors. I hope this helps. And that was Wat ur asking right ?
