94Z28 BCM Question
94Z28 BCM Question
Does anyone know what all the BCM controls in a 94Z28 camaro? Also curious if GM used the same harness for all the 94 - 97 camaro's ( V6 & V8) as well.
I pulled a harness from a V6 donor car this weekend (includes the head light, fog lights, turn signal lights, running lights, ABS, chassis fuse block, fans, windshield washer pump, cruise control.... runs behind the slave cylinder through the fire wall and plugs in to the BCM and a spot along the steering column). Before I sink my teeth into swapping mine out, trying to prepare myself for any BCM related issues, primarily the connector from the harness to the BCM.
