Turbo wot pulls with hptuners...log and tune inside
Old 01-11-2012, 06:00 PM
bwy23's Avatar
Default Turbo wot pulls with hptuners...log and tune inside
Just wanting some other more seasoned eyes to make sure im goin in the right direction. Im commanding 11.4 during wot for the boost. Ive done a few lower gear pulls with no prob but had to back out during 3 and 4th gear runs because the afr started rising. The enclosed tune is after the log....all i changed was increase the 100-105 kpa row in the ve and secondary ve to try and compensate for the leaning out. I know the table is spikey on top but im more concerned with hitting my afr target before i do alot of smoothing. stock heads, manifolds and cam. running trick flow 48lb injectors with 68-70 lbs at the rail and an aeromotive stealth intank pump. around 5-6 lbs max boost right now tr6 plugs. msd wires. thanks for taking the time to look at this. i do know that the timing is conservative as well. still getting some kr...but i think this is from the choppy ve?
Brandon
File Type: hpt
File Type: hpl
Old 01-11-2012, 07:29 PM
edcmat-l1's Avatar
It's spiking really lean. You're gonna hurt it if you keep that up.
Seems like it's probably seeing different levels of boost based on load. Hard to tell without seeing a boost gauge or a 2 bap MAP. I never like tuning turbos in 1 bar. I'd be running a 2 bar COS.
Old 01-11-2012, 08:01 PM
ZTwentyAteU's Avatar
I didn't look at it, but if you are not at least running 2 bar, you should be. You wont have to fight it
Quick Reply: Turbo wot pulls with hptuners...log and tune inside
