Tuners - Need Opinions on Data Logging Software
LS1TECH Sponsor
Well my Auto Tap cable took a dump on me today so I am in the market for a data logger. If money was not an issue and performance / features were, which one would you use?
Mikey
Mikey
How sure are you that it's the interface? The external cables are replaceable - and EFILive uses the AT interface, so you'd need a new one anyway.... Is it under warranty?
efilive, but i'd wait for their FLASHscan cable that can reprogram the ecu.
that way you dont have to upgrade again.
efilive ownz for datalogged im afraid to say. haven't seen anything as EASY and powerful.
I had a wire break in one of my A-tap cables right at the end. The module was fine. I just got a new 9 pin connector and cut the old one off and soldered the wires on the new connector. The cables are easy to check with an ohm meter for continuity. If you're going to get a new logger, send me your broken A-tap cable and I'll pay the shipping.
