Can I remove my computer and my lights still work?
I have a 00 camaro and I would like to remove the stock computer and wiring harness. Im going to a carbed setup and want to remove as much clutter as possible. My question is if I remove the computer will this cause my lights to not function along with turn and brake?? thank you for your help
yes....
just keep the BCM that is up under the dash in the passenger side...kind of against the side of the car...in the kick panel...
also, BCM is looking for a VATS signal to activate the starter relay and fuel pump relay...
so you basically have to wire around it for the car to crank and run the fuel pump...
no big deal
no big deal
