Clutch in disables throttle cracker??
Okay i have a 2000 ws6 with a 2002 custom Speed density OS and car will idle and drive perfect,if im cruising and put the car and neutral and let the clutch out it will settle to idle perfect and i can see the throttle cracker and follower working in the scanner<UNTIL I PUSH IN THE CLUTCH PEDAL. then they zero out right away and the rpms will drop off fast,sometimes killing it.Is it normal for them to zero out when the pedal is pushed in
