Best way to adjust idle so it does not almost stall
Old 06-05-2012, 06:33 PM
brownz's Avatar
Default Best way to adjust idle so it does not almost stall
I just had a tune done on my 2002 ls1 this weekend and Im still having a stubble issue when I dump the clutch. I have a torguer v-3 cam and my tuner said its hard to get them to idle out smooth.
My question is how or is it possible to get these engines to idle out smooth and not almost stall. I understand the rpm's might hang a little but what is the best way to adjust this and not have a high idle? and also be able to use the a/c
I hope this makes sense Im new at this.
Thanks
Old 06-05-2012, 07:59 PM
redtail2426's Avatar
an experienced tuner will be able to do this for you.Using the throttle cracker,rolling idle tables will take care of this problem,but everything else needs to be in line first,like braf,timing and fueling in the idle areas also.
