LQ9 Pulsed Cooling Fan output?
Old 06-12-2012, 12:27 AM
hzemall's Avatar
Default LQ9 Pulsed Cooling Fan output?
I have a LQ9 swapped in to my 79 C-10 with the Painless harness. It uses the OEM ECM and it sends out a cooling fan signal when it reaches temp and kicks on a 30 amp relay in the Painless Gen III fuse/relay box.
BUT, when it get to temp and kicks in the relay opens and closes none stop, sound like the turn signals are on.
Has anyone run into this? I can't see anything in the HP Tuner software that would make a difference with it.....
Thanks
Old 06-12-2012, 07:26 AM
Old Geezer's Avatar
What PCM are you using???
Old 06-12-2012, 12:03 PM
hzemall's Avatar
i dont remember which one but its either the 89017733, 12576106 or the 12583560. Those are the ones Painless requires you to use with their harness. It's all based off of the 2002 4.8 parts I am told (ecm, tac, pedal etc)
Old 06-12-2012, 12:54 PM
LS1MCSS's Avatar
You do have it wired for a ground signal from the pcm, don't you?
Old 06-12-2012, 01:13 PM
hzemall's Avatar
The painless harness takes the ground out from the ECM and runs it through the relay in the painless fuse box and give it a 30amp pos output
