Holley HP won't connect to laptop
My HP unit quit syncing to the laptop all of the sudden. I didn't have a lot of time to look at it (had to work) has anyone seen this? Has anyone seen this before? When I went to start the car it also wouldn't prime the fuel pump at first. My ignition switch is getting worn and I had to leave the key between the start and run position before it would prime the pump. Could this be causing my problem. The car runs but I put a new throttle cable on it and I can't even do a TPS reset now.
