Guide for scaling injectors?
Old 06-26-2012, 03:14 PM
Fondle's Avatar
Default Guide for scaling injectors?
I bought some deatschwerks injectors a while ago and getting ready to install them now, But i cant find any other people who have used them before or any info on them
What is the most effective way of tuning injectors and getting it to idle right?
Old 06-26-2012, 04:02 PM
salemetro's Avatar
Entering the correct voltage/flow offset info, and flow rates @ kpa break points that are specific to the new injectors at your actual rail pressure. Is this the info that you're looking for?
Old 06-26-2012, 07:54 PM
ZL1Killa's Avatar
did they give you data for them?
straight from their website, they likely don't just give this out, you have to pay for it to be done:
Our Dynamic Service features a full teardown and ultrasonic cleaning followed by a rebuild of all replaceable seals and filters and finishes with our industry-leading dynamic flow testing process. All of your results are laid out in an easy to read report.
Add a Pretest to see before and after results.
A new addition is our Advanced Injector Testing, intended for tuners and calibrators needing injector characterization data to aid in setting up an aftermarket ECU. We offer a linearity test and a battery offset test.
Quick Reply: Guide for scaling injectors?
