Question about injector wiring...
Old 07-27-2012, 03:57 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Default Question about injector wiring...
I'm hooking up my Aquamist meoh/water injection and it runs on injector duty cycle, so I need to tap the signal and ground wire for the #1 injector. I'd prefer to do it at the pcm, so does anyone have a chart or location guide to the pin-outs for the PCM in a 2000 f-body?
I'd hate to have to undo all of the wiring harnesses to trace it back.
Ok, thanks to this link:
http://www.lt1swap.com/2001_PCM_CONN_PINOUT.htm
I know that it's #36 on the blue harness for the signal wire, but what about the second wire coming off the injector harness, does that go back to a common ground?
I don't think it would matter, but I'm just not sure.
Old 07-27-2012, 04:11 PM
LS1Tech Sponsor
Slowhawk's Avatar
The injectors have a common power. The ground gets switched.
Old 07-27-2012, 05:47 PM
UNDER PRESSURE MOD
Ok, so the signal wire is the actual ground, and then I just need to tap a positive source. Thanks.
