HPTuners/LS3 injector swap runs VERY lean
I had some smaller racetronic injectors and swapped to LS3 injectors. I have verified fuel pressure (58psi) at the rail, injector polarity (if it matters) and that the injectors are firing (pulled rail and placed towel under all the injectors).
The issue is that the LTFT's are maxing with the VE at what I had with the racetronics. If I add 50% to the VE I get close to 0% trims. There is no way Idle requires 96% in the VE. I am also using a 1bar SD custom OS. The 1bar Custom was running fine with the racetronics. I have also verified AFR with the NB and WB.
I used the data posted in another thread/ls1tuningguide.com and checked it against a couple other sources. I also verified the P/N of the injectors to confirm LS3 42lb.
Could you folks please take a look at my tune and see if I am missing something glaring.
Also note that it starts fine, during OL it runs like **** then once it's warm and CL kicks in it runs fine again once the LTFT's max out. I'm thinking something with the PW is off but am not sure what to try.
I've also posted this on the HPTuners forum but haven't gotten anything after three days.
Thanks,
Patrick
Thanks,
Patrick
