PO704 Low Input Clutch Switch Error
Old 07-30-2012, 10:52 AM
95mysticta's Avatar
LS1Tech 10 Year
Default PO704 Low Input Clutch Switch Error
I just threw this code and had it cleared. The code came back that night. The starting after the code didnt seem to bad one or two longer then normal starts. Took it for a long cruise today and started fine but had 4-5 stops along the way and it look alot of cranking to finally get to start each time. Does this sound like a bad clutch switch/out of adjustment or a fuel pump problem? BTW a common issue with this code is cruise wont work but mine still does.
Quick Reply: PO704 Low Input Clutch Switch Error
