Need Help Updating VE Table - Getting weird #'s
using efilive version 6.4 and log file analyzer version 0.5.
when I go thru the instructions for the file analyzer I get values 5 thru 8.
multiplying these by 30 to come up with edit values are obviously way off.
how are you all crunching your log files and building your ve table?
thanks.
thanks.
Resources I've found and started
I'm going through the same thing right now . I started these two threads and they have some information I've been able to find and some that people have posted. I'm hoping I can resolve this later on tonight when I get home from work. I'll post back if I figure it out. As far as VE Edit numbers I'm using hptuners and the table in that is in VE% so maybe someone else can help you out there. From what I've heard you time % by 30 or something like that. Hope this helps alittle for now.
http://www.hptuners.com/forum/YaBB.p...num=1080973033
https://ls1tech.com/forums/pcm-diagnostics-tuning/156935-help-calculating-ve.html
VE Edit Value Discussion
I believe this is the thread that is talking about VE Edit.
https://ls1tech.com/forums/pcm-diagnostics-tuning/149741-ve-table-cracked.html
