A couple WB/NB Questions
Old 10-18-2012, 07:13 AM
WKMCD's Avatar
Default A couple WB/NB Questions
98 C5 with upgraded PCM
I run a PLX unit in my car with a Bosch WB sensor in the left side and a NB in the right side. Both are getting a little old, the car is not running as well (smoothly) as it used to and the gauge is a little funky. MPG is also way down. I think it's time to replace the 02 sensors.
First Question: I'm sitting at my desk and want to order the sensors but I'm not sure if they are Type A or B. Anyone know which I should order?
Second Question: From what I read the NGK sensors seem to be superior and last longer. Opinions on that and are they compatible with the PLX unit?
Third Question: Part numbers for the NGK WB and NB.
Thanks,
Kevin
Quick Reply: A couple WB/NB Questions
